A wide range of repair guides and support for the consumer-grade laptop computer line by Toshiba.
Windows Activation error code 0x44580
Can't get on computer windows error code 0x44580 comes on says enter password which I have no idea why it is
Add a comment
1 Answer
This is looking to be a malware issue, only thing for it is a reinstall of windows ( Link to microsoft site to show findings: https://answers.microsoft.com/en-us/wind... ) .
FIX:
You can get the licence key for your current build by: God to your start menu, type in “My PC” or “This PC” depending on your windows version, right clicking on the icon, click on “Properties”, scroll down to “Windows Activation” and below that you should see your activation key. TAKE NOTE OF THIS! write it down, take a pcture of this on your phone, just make sure you have this clearly notes and safe, you will need this later. Also when doingf this on the same page note down if it is a 32 bit or 64 bit machine you are running (if its windows 10 99% you are on a 64bit build but please double check this and again NOTE THIS DOWN for later reference.
Go to microsoft software section ( https://www.microsoft.com/en-gb/software... ) and select the version of windows you have. Click the “Download tool now” link below the “Create Windows (Version) installation media” tab.
From here follow the instructions given on the microsoft page for the instaation. Remember when prompted for the install type, put in the build you had (32 bit or 64 bit) and when asked for an activation key input the one you took not of earlier (told you that you would need it ;) ).
Once the instrall is compleate reinstall all apps lost, plkease install an antivirus (IMPORTANT) and lastly remember that torrented software is a huge risk, links in your emails are not to be trusted unless you are expecting it and avoid any non safe websites as these are all risks to the health of your machine.
Add a comment
Add your answer
Becky Gilman will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 18
All Time: 244
