Lens error, lens won't come out of the barrel
When starting it up the lens won't come out of the barrel and a message "lens error" shows up.
Is the lens part serviceable? Replaceable?
A whole range of different faults can cause Lens Error, both electronic and mechanical. If it's a mechanical problem there are a few things you can try listed at https://wiki.restarters.net/Compact_came...
If none of those work, realistically, your only hope is probably to look out for another camera of the same model on ebay with a different fault - hopefully you could get one quite cheaply. Swapping the lenses shouldn't be too difficult.
Past 24 Hours: 4
Past 7 Days: 15
Past 30 Days: 35
All Time: 3,328
1 Comment
Thank you for the elaborate answer. I am afraid I will need to buy a new one...
by Joost Lomans
