The Samsung Galaxy Note 5 (called the Note5) is a phablet-style phone with stylus, manufactured by Samsung, released in August 2015.
271 Questions View all
Is there anyway to power on note 5 without power button?
[http://]
i damaged a part of PCB at power button area is it repairable ?
Update (01/01/2017)
some micro part
see this attachment
http://www.imageno.com/tu87c2lyldc4pic.h...
Update (01/01/2017)
those three micro parts connecting power button
Score 1
4 Comments
What kind of damage? Did you damage the pads?
by
@saadsmh looks like somebody just put a blob of solder across those. Why not repair it properly with the right parts?
by
and one of that micro part was burnt too
by
@saadsmh which part? Take a better picture and mark the burnt out part on that. The one you linked to is not quite clear. Right now it looks like you just jumped the two switches. Use this guide Adding images to an existing question to add the images to your question.
by
Add a comment
Chosen Solution
That is some jacked up ish. Is that just globbed solder on the pads? Are any of the small components missing or damaged there? If I were you I would just buy some contacts and just solder them back on, all you need is a heat gun with a concentrating nozzle and some flux. I'd clean all of that solder off of there, clean it up with iso alcohol and then take a picture.
Score 1
Add a comment
Most Helpful Answer
@saadsmh
  • When your phone is off, press and hold the Volume down and Home button.
  • While holding the Volume Down and Home, phone to your computer using a USB cable.
  • Continue holding the Volume Down and Home button to until your phone will boot to Download mode.
  • Once your phone boots to Download mode, press on the Volume Down button to cancel the Download mode.
  • Once the Download mode has been cancelled, your Galaxy will reboot.
  • Wait for your phone to completely start.
Score 3
3 Comments:
this doesn't works with note 5 i already tried
by
In that case, I suspect the power button is not the only issue.
by
it doesn't works on other note 5 without a power button.. only problem is www.imageno.com/tu87c2lyldc4pic.html this is damaged
by
Add a comment
When you connect UART cable on Note 4 then it turns on without pressing powerbutton. Try on Note 5, it might work.
2 Comments:
I'm newbie can you please tell me how to make a uart cable?? or tell me more about uart cable so thar I can buy one
by
I would just buy a pre-made UART cable from the Internet.
http://www.ebay.com/itm/like/40118376599...?
by
Add a comment
I have the same problem but, i want to open up the phone to see whats wrong but i have another problem. My back glass of my Note 5 is all cracked. Would there be a problem if i remove the back glass if its all cracked?
2 Comments:
Hi Ronerto,
There would not be any issue if you remove backglass
Kind Regards,
Karar Haider
http://www.mmstore.be
by
Thanks, this tip helps me.
Regards,
Joe
https://couponsabc.com/
by
Add a comment
how can i turn on my samsung note 5 without using a power button
Add a comment
Thanks, this as really helpful.. !!!
Robin (Askmeoffers)
Add a comment
Is Amazon Prime the right choice for you. You will need to ask yourself the following questions in order to get a better idea if indeed it is. My first question to you is: Do you like watching movies at home? With Amazon Prime streaming video you can do that and not have to pay for the movies or shows you love. With over 40,000 choices that you can watch on Television, on your laptop or Fire TV, this is an amazing deal in itself.
With Prime you do not have to pay that $2.99 or $4.99 for each movie you want to watch. That is a good deal if you are a movie lover and watch a few movies each week. If let's say you rent 5 movies a week at $4.99 each movie, that in itself for that month is going to cost you $24.95. Multiply that by 12 and well, you are paying about $299 for the year in movies, while Amazon Prime costs only $99 for the year. There is a amazon coupon prime.
Add a comment
Add your answer
syed will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 25
All Time: 12,835
