The Apple Magic Mouse is a multi-touch mouse manufactured and sold by Apple Inc. It was announced and sold for the first time on October 20, 2009.
Why won't it turn on?
Inserted new batteries. Batteries are in properly. Battery & mouse contacts are clean. Green power light does not come on. Mouse does not function.
Add a comment
1 Answer
Chosen Solution
You may have some corrosion internally within the mouses logic board. Have you tried opening it to see if you need to do some deeper cleaning? Also you could have a bad solder joint in the power section . Trace the power feeds from the battery compartment with an Ohm meter and don't forget the switch.
Sadly, Apple does not offer parts for the mouse so if you have a bad switch you'll need to get a new mouse.
Score 2
Add a comment
Add your answer
Joe Milun will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 231
