make this into usb
So i just bought an logitech Driving force Shifter, and want to make a standalone version, cause i dont have the wheel for it, and i figured they use SUBD9 Connector, well only one, and i hoped to get some help from anyone, that could help me make this happen to become a usb connector?
i have an arduino i could use to convert the SUBD to the usb through arduino
i watched this guy here but still yet i didnt get much out of it..
4 Comments
I doubt you could do that.
by
well @pccheese haha lets hope i eventually will come up with something :) :P
by
Good luck! You'll need it. Not only will you have to adapt the connector, but you will have change the firmware to accept this new interface.
by
Add a comment
Most Helpful Answer
You are correct. Logitech says that the shifter connector is a DB-9 Male.
So maybe this will work?
https://www.ebay.com/itm/8-Inch-0-25m-RS...
Score 2
Add a comment
Nothing but a new usb controller will work , the shifter is only a axis with the mechanism, nothing else , no board, no chips, you need a Arduino to map the axis coordinates into buttons in order to work
Add a comment
Add your answer
Petter Berget will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 8
All Time: 3,285
