Why my power bank not charging
When charger switched on... all four led lights get on and not blinking. If i connect the power bank to my phone it is not charging.. what is the solution
Hello.
I had the same problem.
After opening up my Xiaomi 20000mah power bank, I discovered that the positive terminal to the battery on the regulator (circuit board) was disconnected.
Simply soldering the two pads together should fix your problem.
I also have some pictures of the connected terminal and the solder fix
Hope this helps.
Credit: http://www.myfixguide.com for the teardown power bank picture
When your Power Bank Not working Properly or not charging your phone Properly, then what would we have to do? Get some idea from here http://articlescad.com/article/show/1099...
Noting to be worry about. Just press the power button for more than 15 secs and see the magic…✌
Nothing is happening bro
Hold the power button & plug in charging cable for more than 15s. It works for me.
I have 2 usb a type and one type c port
Only one type a port is working
Past 24 Hours: 6
Past 7 Days: 48
Past 30 Days: 219
All Time: 42,741
19 Comments
Because all four lights are on, that likely means it's fully charged. What is your phone, and have you tried another USB cable?
by George A.
Same day, same thing. Is this a sign?
by Huda Diaz
Hello Shankar,
Your prob is actly as I m facing right now...
Regards,
Hemant.
by Hemant Sarankoti
My Xiaomi 20000mah power bank shows one blinking light. It charges the phone for sometime and then stops charging. When I put the power bank for charging only one light blinks for sometime and then all four lights start blinking together but the power bank doesn't charge. Any solution please.
by Vicky Sunny Murmu
Have you found the cause?
This is also happening to my powerbank
by niels_barts
Show 14 more comments
