Nintendo's first 3DS handheld device released February 2011, identified by model number CTR-001.
My a button is not working
The a button that u click it clicks but it dosent respond
Add a comment
1 Answer
Most Helpful Answer
Having run into this issue quite a few times over the years, your problem is most likely in the button membrane just underneath the button it's self and/or the contacts under the membrane on the system board. I have seen carbon build up on the contacts causing the button to malfunction. My suggestion for you is to purchase a new membrane for your 3DS and then clean the contacts underneath the membrane with rubbing alcohol and then using a pencil eraser, clean the contacts after the alcohol has dried. Then reassemble the 3DS.
Score 1
1 Comment:
But what if you cant get the screw of the back of 3ds?
by
Add a comment
Add your answer
olivier cazeau will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 14
All Time: 120
