Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
1169 Questions View all
Battery replacement intermintent on, then permanently off
I just replaced the battery in my iphone 3g yesterday. I put everything back together and powered the phone on successfully and charged it all the way. I made phone calls played games the works, no problems. Then today I went for a motorcycle ride with my phone in the jacket. It was cold out but not wet. The phone would turn itself off at random. Now tonight I was listening to some music on the ride home and the phone shut off for good this time. I tried taking it apart and placing th old battery back in but its a no go. Nothing happens. I tried powering it on with just the sleep/wake button and holding that plus the home button for over a minute. Nothing. Please help guys.
Score -1
2 Comments
Anything happen when on wall charge?
by
Nothing happens when plugged into a wall outlet or usb to the computer
by
Add a comment
1 Answer
Chosen Solution
option 1.battery/batteries completely dead (not likely that both would die beyond even a slight charge) measure the voltage? should be in the region of 3.7mAh. check the connection to the batteries is secure (under/near don''t remove sticker)
option 2. charger/usb cord is not working properly
option 3. dock connector problem-battery ran down and now you can't charge-look at connector 4, clean port etc, think about replacing
option 4. power processor....
option 5. bit out but check connector ?5 headphone jack which is also power button.
Add a comment
Add your answer
timothyarnott will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 540
