Released June 2012 / Core i7 processor with Turbo Boost / Up to 1 GB GDDR5 Video RAM
596 Questions View all
Mac won't turn on, replaced DC board.
MagSafe Burned out. Won't turn on.
/\ PREVIOUS POST 10th Oct /\.
Hello there,
Back in october my Macbook had a spark sound from the DC-in and my laptop shutdown with a burning-like smell from the ports.
After all this time, I finally managed to find time and funds for the DC-in replacement, I have followed the iFixIt guide of replacing the DC-in board.
After the replacement (around 15 minutes ago) and connecting the charger to the laptop, the charger stays green and the battery check button on the side shows 1 green dot which slowly fades away after a while, it doesn't blink which it should while charging the device.
Although there isn't any more burning smell from the ports, the device still doesn't turn on.
I have been advised to do some sort of Coconut battery check although I cannot access the mac due to the fact that it simply doesn't turn on.
I'm not sure if I should change the battery or not but if the problem lays in the motherboard (which a replacement can cost around £200) I'm not sure if I should even carry on with the fixing of the mac.
Can someone please let me know any sort of advise on the issue? Should I try and replace the battery or should I just dump the whole thing and get a new laptop?
Add a comment
1 Answer
The issue is definitely not in the battery, and is most likely in your motherboard, unfortunately :(. When your DC-in board was destroyed, the surge of electricity likely took out another important part of your motherboard - this is fixable, though! Take it to a store that does component-level motherboard repair and see what they charge.
Add a comment
Add your answer
Patryk Orlowski will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 90
