The Samsung Galaxy Note 4 is a cellular smartphone that was released in October 2014. The Galaxy Note 4 Model Number is SM-N910, SM-N910A, SM-N910T, SM-N910V, or SM-N910R4 for American variants.
256 Questions View all
Not powering on, not resetting,but charges battery
So ive looked through tons of possible answers for the Not powering on thing no one has been able to help me solve this and I just don't have money to take it in. Is there a possibility of me fixing this. I plugged it in this morning. It actually showed the percentage but once I hit Tue power button the screen shut off and hasn't turned on since. This was after it wasn't powering on already. I've dome the discharge method where you take the battery out and press and hold the power button for a few mins to discharge and then try again but nothing. I also have tried to do that and the soft and hard reset versions. Phone doesn't vibrate PR power back on at all. I charge it and there's no heat so its not a charging issue or bad battery. I can't figure put why the screen works but it won't power on. Any help guys? Thanks!
Add a comment
Chosen Solution
Does it shows battery charging sign? Like percentage?
2 Comments:
It's a board issue. We have repaired few dead Note 4 by replacing both the power ic chips on the board.
by
Thank you Amir! I'll go get it checked and replaced. Appreciate you taking the time to answer
by
Add a comment
When I wrote this it showed 0% when I first plugged it in, then stopped snowing anything. It also still doesn't power on.
1 Comment:
by
Add a comment
Add your answer
Elijah will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 5
All Time: 112
