Why dose my turn signal stop working when I apply the brakes
Ok I've changed brake light switch signal light switch disconnected rear lights third break light still when I apply brake signal stops
@afifield , Ash, Help ifixit help you with a little more info. year, make, model,engine, transmission so we can answer your question better.
Did you try changing the signal light flasher, are all the bulbs good, check all your lights grounds for corrosion and tight.etc. in the rear light harness, do you have a trailer light harness installed(the wires or converter may be bad/try removing). Good luck.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 3
All Time: 76
1 Comment
Did you try changing the signal light flasher, are all the bulbs good, do you have a trailer light harness installed, check all your lights grounds for corrosion and tight.etc.
by L Pfaff
