The Mac Pro First Generation is an Intel Xeon-based workstation computer manufactured by Apple Inc. The first generation model includes the machines from 2006 through 2008.
Leak on CPU board
I have the Mac Pro early 2009, 8-core; CPU board has an old stain which appears to have been a leak, pretty large, on the surface of the right side. Is there liquid coolant in the heat sink? I can see a copper pipe in between the vanes. I thought liquid cooling was abandoned after the G5 problems.
Machine still runs fine so I don't know what to make of it or if I should replace the board.
Add a comment
1 Answer
Chosen Solution
Yes! The heat transfer tubes are filled with a coolant which has now leaked out.
I would stop using the system until you get the heat sink repaired otherwise you risk damaging your system.
Score 1
Add a comment
Add your answer
majus will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 116
