Unveiled at the 2000 North American International Auto Show on January 10, 2000, the redesigned 2001 Dodge Caravan and 2001 Chrysler Town & Country were released for sale in August 2000.
179 Questions View all
heater fan not working properly. only works on lowest setting
have 2005 dodge grand caravan. every thing was ok until recently when the front heater fan stopped working. can it be a fuse somewhere, or something like that? if so where do I look for it ad fix it?
Add a comment
1 Answer
Chosen Solution
Hi,
Most likely if it only works on the lowest speed then the blower motor resistor is faulty.
Here is an image that shows where it is located in your vehicle. Click on image to enlarge it for better viewing
To gain access to it :
Disconnect and isolate the negative battery cable.
Remove the passenger side cowl trim panel.
Position the carpet to access the front upper screw that secures the air inlet housing.
Remove the re-circulation door actuator.
Disconnect the blower motor wire lead connector from the blower motor resistor.
Here is a link to just one supplier of the part, there are others just search online.
http://www.oreillyauto.com/site/c/search....
Score 2
Add a comment
Add your answer
swlt031 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 3,718
