The Apple iPhone 5s was announced on September 10, 2013. Repair of this device is similar to the previous models, and requires screwdrivers and prying tools. Available as GSM or CDMA / 16, 32, or 64 GB / Silver, Gold, and Space Gray.
3508 Questions View all
it donesn't show wifi
Hi,
I have problem with my iphone 5s, it donesn't show wifi is not show on the screen and I can't use any more.
thank you.
Comments:
Add a comment
Chosen Solution
@gineb Is the phone in airplane mode ? Is the WiFi even turned on , it hapens . Does the phone work other than the WiFi. Can you make calls, receive text, use the apps that don't require WiFi. Are there any other issues with the phone other than the WiFi. Has the phone been dropped or has it got wet? Can you see networks when you select your WiFi in he settings or is this field blank.A little more info will go a long way to answering your question
Score 1
Add a comment
Wifi failure can be caused by multiple things.
1) make sure airplane mode is off. if it is on, it will permanently disable wifi.
2) Make sure wifi is enabled in the settings.
if the wifi is not greyed out, replacing the wifi network antenna modules will likely fix the issue.
if the wifi setting is greyed out, then you are likely looking at the baseband IC failure, in which you will need to replace the motherboard to repair.
Score 1
Add a comment
Add your answer
Issa will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 63
