Repair information, troubleshooting tips, and guides for the sixth iteration of Apple iPhone, announced on September 12, 2012. Model: A1428, A1429
2522 Questions View all
phone died and won't come back on.
recently, an iPhone 5 was passed to me from my older cousin. It worked fine up until yesterday the phone died at around 50% and it has been charging ever since but won't turn back on. I've tried the home & lock button technique but nothing worked. Any thoughts??
Add a comment
Chosen Solution
I'll also add that if the lightning cable does not plug in fully into the charging port leaving a visible gap between the plug and the housing then it is a good indicator that the charging port may have some debris stuck in there.
If this is the case use a toothpick or something equivalent to remove it so that the charging cable can have full contact with the charging port pins.
This is a common cause due to it obstructing the connection from the charging port pins and the charging cable.
Score 2
Add a comment
Most Helpful Answer
How old is the phone, it may be time for a new battery
Score 2
Add a comment
Add your answer
Trey Lastname will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 69
