7.9 inch display / Model A1432 / Available in black or white / Announced October 23rd, 2012 / 16, 32, or 64 GB capacity
220 Questions View all
Glue residue is stuck on digitizer screen
I was removing a cracked screen and it slipped out of my hands and fell back on the digitizer. The edges of the cracked screen still had warm glue on it from taking the IPad apart. I know I am not supposed to apply pressure or use alcohol to clean digitizer screens. So what would be the best way to remove a long streak of glue on the digitizer? I tried disstilled water and microfiber cloth and got some off but there is still alot on that you can clearly see when the device is turned on.
Add a comment
1 Answer
Chosen Solution
I think we need to get our terminology straight here. The iPad mini has a digitizer (the part you touch) and an LCD (the part that shows the image).
Why was there warm glue anywhere near your iPad and what exactly was the warm glue on; the LCD or digitizer?
The proper way to re-assemble an iPad is to use adhesive strips. You need to clean off the old adhesive from the aluminum frame with IPA so that it sets correctly. If you are using a new digitizer, some of them come with adhesive strips pre-installed. They aren't the greatest but not everyone wants, or can buy, separate high quality adhesive. I recommend this adhesive.
Now, if you have glue on the digitizer, what you need to remove it depends on the type of glue you used. If it is epoxy or super glue, try acetone. Whatever you do, don't scrape or you will scratch the surface. If the glue is on the LCD, you are probably in trouble. Acetone might work but don't pour acetone (or any liquid) directly on the LCD. Use a very soft cloth. The problem with the LCD is that the surface is very delicate.You will likely scuff it or damage it by trying to remove the glue. Also be very careful with the black, cloth-like edges of the LCD. That's where a lot of the internal wires run and they are easily damaged.
Score 2
Add a comment
Add your answer
Morgan Ray will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 7
All Time: 992
