Repair information and guides for the iPhone 6 Plus that was released on September 19, 2014. Model: A1522, A1524
1525 Questions View all
Is there another way to fix my disabled phone without resetting it?.,
ok so I had gotten my phone repaired a couple of months ago and so when I went to the dollar store to get a screen protector , I used it , at first I was using my protective case ,then I said well....I do have a screen protector on, so I used my case (that isn't protective)..which one day I saw that the side of my phone wasn't on correctly(my right side of my screen) so that's when I said well my phone works so it will be ok so then , 2 months ago my p button on my phone wasn't working so then I thought it was just my phone protector that wasn't on right was the problem , so 3 days ago I was getting food , I handed my phone to my baby sister, she dropped it , which it didn't drop front wards it dropped backwards so then I hopped in the car and the bottom part of my screen wasn't working so then I tried to put my passcode in ,it worked and my pass code starts with an 0 ,,... so it wouldn't let me type it in, so Monday night I though well if I shut It off then turn it back on in the morning it might work so then I turned it on Tuesday morning and it required my code so I couldn't use finger print then I panicked, tried to hit buttons and then it said wait one minute, then 5 minutes, so the I did 15, and then 1 hour then at school I tired again so now it says "disabled" and I don't want to reset my phone soooo pleaseeeeee helppppppp meeeee asap before the holidays
Add a comment
1 Answer
Sorry if disabled it needs to be put into recovery mode, plugged into itunes and factory reset, you will loose everything on the phone. However if you have a backup this can be reinstalled after the reset. Problem is the itunes restores your phone it will check your phones working ok, it may crash due to your home button or screen not working.
Add a comment
Add your answer
tonia robinson will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 3
All Time: 131
