Why is my screen image and fonts so erratic?
Image size can go from 200% to 10% for no known reason . This is my wife's laptop - problem started after change from W8.1 to W10. Looked at settings but cannot find anything to suit. To go back to W8.1 aand reinstall W10 will cost us £100.
1 Comment
Hi
What is the model number of your laptop?
Does this happen when using a particular program or does it happen anywhere, e.g. even the desktop?
Try booting into 'safe mode' and see if it happens.
http://www.digitalcitizen.life/4-ways-bo...
If not then a program is causing the problem. When in normal boot mode, use startup tab in task manager to see which programs are loaded on startup. One of these may be causing the problem.
Have you checked that you have the correct Win 10 graphics adapter drivers for your laptop from HP?
May seem a bit odd but try connecting an external monitor and see if its display stays OK.
by jayeff
