Nintendo's upgraded version of the Nintendo 3DS. It features bigger screens, longer battery life, better pixel density, and a better design.
413 Questions View all
I've got the Black Screens of Death on my system, how do I fix it!
I bought this system in 2013 brand new when the Pokemon X/Y game came out, so yes, it is an older model. I took good care of it, and the only damage it sustained was some minor nicks from dropping it once or twice and the screen being scratched on the sides where the bottom lid meet the top (which I will look into repairing also at some point). But one day, in May of this year, I turned off my system normally and went to bed. When I woke up and turned it on, the screens stayed black on both sides. No sound produced from the system either and the wifi light would not turn on. The only thing that even showed that it was turned on at all was the power light, which indicated that it had full enough power to be a Green light.
I went online, naturally, to find out what could be wrong and how to fix it. Everything I read lead me to believe that it was an internal issue that could either be fixed with wiggling the wifi cord (wherever that was) or was only fixable by Nintendo themselves with a repair or a full replace of the system.
Naturally I don't want to spend money on a new system if I don't need to; if I'm going to spend anything, I might as well do what I can to try and save it. I was lead here, finally, by a family member and am already intrigued by how there are whole guides on how to disable the device when most of the places I went just gave a kind of "Don't even bother" kind of answer.
I'm going to keep poking around online here, but I wanted to ask if anybody has any answers on what I should do or look up or try. If you've personally had this happen to you before, what did you do to fix it? Am I doomed to have to buy the new product or even send it to Nintendo to just fix it on it's own, or can I get the parts I need myself?
Any advice is most appreciated!
Add a comment
1 Answer
BSOD, the infamous Windows error abbreviation, does not exclusively stand for "Blue Screen of Death". A slew of Windows 7 users have experienced having a "dead" PC with only a mouse cursor to interact with and a black screen to boot. In an allusion to the original BSOD, which was a label the Windows community gave to the blue error display that pops up after a system crash, the issue was named the "black screen of death."
There are different variations of the "black screen of death" depending on what caused the problem. Some BSOD instances could still allow the users to summon the Windows task manager and perform functions. However, more severe cases left the users with just a dead black screen and a movable mouse cursor.
1. Windows security update.
One of the first major culprits for the black screen issue as discussed in the Windows community is a certain Windows 7 security update. Several Windows 7 users apparently stumbled upon the problem after installing, knowingly or unknowingly, the security updates code-named Update KB2607712, Update KB976098 and Update KB915597. While Microsoft has rebutted this claim, a slew of Windows users still claimed that uninstalling the said updates restored their Windows system back to normal. If you had installed Windows updates prior to the BSOD episode, there is a high probability that this could be the cause of the BSOD issue.
2. Malware.
Several Trojan viruses such as those which belong to the "Daonol" family are believed to be capable of producing "black screen of death" symptoms. If you had not made regular virus scans on your Windows PC prior to the BSOD episode, or worse, if you haven't had antivirus software installed on your system, then it is likely that a malware has triggered this ordeal.
3. Corrupted graphics card driver.
Because the problem involves abnormalities in the system's display, it would be logical to consider an issue involving your computer's graphics card. The video adapter's drivers might have been corrupted or might need some updating.
What are the possible solutions for the black screen of death?
Because there are many possible causes and different variations of the "black screen of death", there are also a lot of possible solutions. The solutions list provided in this section follows a pattern of ascending degree. This means the list starts off with the most basic solution and gradually advances to the more complex ones. It is recommended that you perform the solutions in their order of arrangement. Start with the first one and only proceed to the next if it doesn't work.
1. Boot your PC with the "Last Known Good Configuration" option.
This quick little option can be accessed by following these simple steps:
a. Press and hold down the "F8" button as you boot up your PC and before the Windows logo is displayed. This will bring you to the Advanced Boot Options, wherein a list of options on booting up your Windows 7 system is provided.
2. Locate the "Last Known Good Configuration" option and select it by pressing the Enter key. Your PC should now start booting Windows. Wait and see if it works.
3. Don't forget to cross your fingers.
2. Reinstall graphics card driver.
This solution is only applicable if you can still access the Task Manager of your Windows 7 computer.
a. Press and hold down the following keys: Ctrl + Alt + Delete, to access the Task Manager.
b. Go to the Processes tab and find "explorer.exe".
c. Right-click on the selected process and select "End Process".
d. Create a New Task by clicking "File" and "New Task" (Run).
e. Type in "explorer.exe" in the text box and click "OK". The Windows taskbar should now be visible.
f. Click the "Start" button and search for Device Manager by typing "device manager" in the Windows search box. Click the search result.
g. Locate the "display adapter" option and double-click it. This should show your device. Right-click on the device name and then click "Update Driver Software".
h. Follow the instructions in the update driver wizard.
i. Don't forget to cross your fingers.
3. Uninstall Windows security update.
Click the "Start" button and search for Programs and Features by typing "programs and features" in the Windows search box. Click the first search result.
Locate the "View Installed Updates" option on the upper-left portion of the ensuing window and click it. A list of installed updates will be displayed.
Locate the updates under the "Windows" category.
Observe the name of the updates and the dates they were installed. If there are updates with the code name KB2607712, KB976098 and KB915597 and they were installed immediately prior to the occurrence of the "black screen of death", uninstall them by right-clicking on the update name and clicking "uninstall".
Restart your computer. And don't forget to cross your fingers.
4. Check Windows registry.
Create a New Task by clicking File and New Task (Run).
Type in "explorer.exe" in the text box and click OK. The Windows taskbar should now be visible.
Click the Start button and type in "regedit" in the Windows search box. Click the first search result.
Navigate to this particular registry location: HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon
Click the WinLogon key. On the right pane of the window, find the "Shell" option and click it. The value of the Data column should be explorer.exe. If it isn't, change the value by double-clicking Shell and typing "explorer.exe" in the Value data input field. Once the change is made, click OK.
Exit the registry editor and restart your PC.
Cross your fingers.
5. Uninstall Windows security update via Windows "safe mode".
If you can't access the Task Manager, you can boot your Windows PC into Safe Mode and uninstall Windows security updates from there. To do so, follow the steps below:
Press the "F8" button on your keyboard upon booting up your PC. This will bypass the normal boot process and leads you to the advanced boot options instead. Note: There is a small window of opportunity for this process to work so you may want to press the button repeatedly to ensure that you won't miss that opportunity.
Click the "Safe Mode" option once you are in the Advanced Boot Options screen. The system will now load the files necessary to boot into Safe Mode. Wait until the login screen appears.
Log on to your computer. If you have many user accounts on that computer, make sure that the account you logged on with has administrator rights.
Click the Start button and search for Programs and Features by typing "programs and features" in the Windows search box. Click the first search result.
Restart your computer into the normal Windows mode (not Safe Mode). And don't forget to cross your fingers.
6. Scan and remove Malware.
If you can't access the Task Manager in the normal Windows mode and if the previous step didn't solve the problem, you should consider scanning your PC for malware through the "Safe Mode with Networking" advanced boot option. The steps to doing this are detailed below.
Press the "F8" button on your keyboard upon booting up your PC. This will bypass the normal boot process and lead you to the advanced boot options instead. Note: There is a small window of opportunity for this process to work so you may want to press the button repeatedly to ensure that you won't miss that opportunity.
Click the "Safe Mode with Networking" option once you are in the Advanced Boot Options screen. This will allow you to have internet connectivity while on Windows Safe Mode.
Open your web browser and download and install the free 1 version of Malwarebytes Anit-Malware software.
Upon successful installation, open the Malwarebytes software and perform a Full Scan of your PC. This may take considerable time depending on the size and speed of your hard disk drives. Wait for the scan to complete and be patient.
After the scan has completed, view the scan results and let Malwarebytes remove infected files if there are any.
Restart your PC and cross your fingers.
7. Perform a System Restore via Safe Mode.
Windows provides a feature for restoring your system to a restore point. You can access this feature via Safe Mode to restore your PC to a previous state by performing the following steps:
Click the "Start" button and search for System Restore by typing "system restore" in the Windows search box. Click the first search result.
Choose the restore point you want your PC to revert to. The restore points come with a corresponding date they were created. Choose the most recent date when your PC worked as expected. Click "Next" and then click "Finish".
8. Perform a System Restore via System Recovery Options.
If for some reason you also can't access the Windows Safe Mode, you can perform the System Restore via the System Recovery Options. Here are the steps:
Click the "Repair your computer" option in the Advanced Boot Options screen.
Choose the keyboard layout applicable to you.
Enter your user account credentials.
Choose "System Restore" in the System Recovery Options window.
1 Comment:
These options would not work on his device. The device is a Nintendo 3ds, not a windows computer or windows device.
by
Add a comment
Add your answer
Ryan Devlin will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 10
All Time: 470
