on a 95 nissan maxima cv joints how do they work with the transmission
cv joints on a 95 nissan maxima what part do they play with the transimissions
Constant-velocity joints (AKA homokinetic or CV joints) allow a drive shaft to transmit power through a variable angle, at constant rotational speed, without an appreciable increase in friction or play.. They are not in the transmission they are on your axle which are then attached to your transmission. In simpler terms they allow the driveshaft to flex and turn so your front wheel drive car can drive and steer.
http://www.samarins.com/glossary/img/cv-...
Hope this helps
@jesusjesus7 , the engine turns the transmission, the transmission turns the CV joints/axles, cv/axles turn the wheels.
Links below will tell you about CV joints and CV shafts in more detail and trouble shooting.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 41
