Released on July 21, 2011. Core i5 or Core i7 Processor. Thunderbolt. This unit is also used to run the Mac mini Server configuration.
204 Questions View all
Can I mix a 8g ddr3 an a 8g ddr3l? (mac mini mid 2011)
Hello guys!
I am now using a 8g ddr3 1600 ram(1.5v) now and mac mini is working fine. Can I install another 8g ddr3l (low voltage, 1.35v) at the same time? Because normal voltage(1.5v) ram is very rare now.
Add a comment
Chosen Solution
Yes, DDR3L is compatible with DDR3 based systems. However, DDR3 is not forwards with DDR3L based systems, if the system requires DDR3L then installing DDR3 may not work. Do make sure all of the other requirements match.
To be honest, I wouldn't mix different brands of RAM which are the same size. You see, your system will use interleaving which is time sensitive (RAS & CAS) so you could encounter some hangs and crashes do to the slight differences in timing of the different units. This is independent of the voltage issue as the DDR3L will still be running at the standard 1.5 volts the DDR3 runs at.
I would just put in a matched pair of DDR3L modules instead here (replacing both modules with DDR3L).
I'm surprised you'er encountering problems locating the cheaper RAM. You may want to order it online from Kingston or other large memory house.
Score 3
1 Comment:
Thank you for your help. I've already bought an DDR3L Ram and mixed them into my MacMini. It's working fine. Both rams are working at 1600Mhz. Mac mini is so COOL!
by
Add a comment
is this ok to do. will it be harmful to my pc
1 Comment:
I think the answer was clear, but you don’t offer enough info to tell you if you have an issue as different systems have different requirements.
by
Add a comment
Add your answer
Tieying Li will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 21
All Time: 15,533
