Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Questions View all
What could cause this bright spot on the screen?
I replaced my earpiece speaker and front camera assembly on my iPhone 6, due to the proximity sensor not working and diminishing sound quality coming from the speaker. After the repair the phone was fully functional again, but I noticed a bright spot on the screen (see link below for photo, circled the spot in red.) It's always visible, but mostly visible when the screen is displaying lighter colors, especially white. It almost looks like something is pressing the back of the screen, but I opened the phone back up and there is nothing in that area that could cause that. The spot gets brighter if I apply pressure to the screen around it, making me think it's some sort of mechanical damage, but I was very careful with handling the screen during the repair. Any idea if I did anything wrong or how I could fix this, short of replacing the display? If a display replacement is necessary could I do it without replacing the glass?
Photo link: http://imgur.com/a/7WHVP
Thanks!
Score 2
2 Comments
I have the same problem came to realize when I put the green protector on pushed too hard in one spot to eliminate the air bubble and created the problem you have to replace the screen.
by
My phone has a bright spot on the corner left when i got out of the restroom. It just shows a light side and most of it is dark
by
Add a comment
Chosen Solution
Actually might just be dust sitting under the metal backplate.
Score 5
7 Comments:
@benjamen50 absolutely right. Could be. I made the assumption that the OP "opened the phone back up and there is nothing in that area " had checked that :-)
by
@benjamen50 Thanks! I'm thinking that's probably it. I used compressed air to clear dust off the backside of the screen before I installed the earpiece, and it's very likely that dust was pushed under the back plate in doing so. Is removing the backplate to clean under it a simple operation? Anything to be careful of? Haven't seen it mentioned in any other how-to's. Thanks again!
by
Yep fairly simple.
You will have to carefully remove the home button and the metal plate by unscrewing it and carefully removing the bottom end of the home button extension cable as it's held in by adhesive. I personally use razor blades and dig in hard under them carefully.
Because there is a metal plate under the home button extension cable. I use a prying tool for the home button cable itself though.
by
@benjamen50 I opened it back up and pulled the plate off, sure enough there was a grain of sand right where the spot was appearing. Gently cleaned the panel and shield off, reassembled, problem solved. Thanks again!
by
Its definitely not dust on the screen. Dust would look something like grey. Its damage to the light diffuser layer of the lcd. In that particular area the diffuser layer is thinner leaking light and creating the uneven lightning you are experiencing.
by
Show 2 more comments
Add a comment
@mmartin932 that looks like a pressure spot. There is no real repair for it. to eliminate it you will have to replace the display.
Score 2
1 Comment:
If it happens, is there any possibility to show future problems.
by
Add a comment
I had a white spot. Upper right hand corner. My iPhone started to crash unexpectedly. And was REALLY slow at the end of a he day. Clunky!
My battery was in guarantee.
Took it in. Battery had overheated. And was misshapen as well causing pressure on screen.
Changed battery and my phone is now lightning fast and good again.
Thank God
Score 2
Add a comment
I have several bright spot also , iPhone 6 a old phone . What I did was
setting > general > accessibility > display accommodations > invert colours > smart .
Eliminated all the bright spot for now.
As long as it doesnt annoy me I won't do anything extra on it as its a spare phone . Battery still works fine .
Score 1
Add a comment
My iphone 6s plus out of nowhere it had a white spot brighter than the screen i have took good care of my 6s plus and my heart stop when I saw that spot I don't know what happened but maybe you guys had the issue?
1 Comment:
It is due to a slightly swollen (bloated) battery pushing from under the screen, that causes a bright spot or patch on the screen. This is a most common problem i have found after a thorough review on my iphone. The battery was replaced and the hazy screen and white patches have disappeared.
The battery health was showing 100% but it was draining at 20% per 30 minutes in video playback mode which is quite a quick drain. Once i replaced the battery, everything got solved.
by
Add a comment
Add your answer
Michael Martin will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 31
Past 30 Days: 151
All Time: 149,987
