Applyied Thermal paste, noticing higher than normal temps, is this tem
Applied IC Diamond 24K Thermal paste to my MacBook Pro 15" Retina Quad-Core.Used the small pea method. Noticing CPU temps idle at 60-80C, 90's C with a load. Does this particular thermal paste take time to settle in to work properly or should I reapply using less paste?
Update (11/30/2016)
Fixed it!
Reapplied thermal past in an "X" like pattern on the CPU and GPU. Idle temps in the low 40's.
