Released on September 19, 2014, this 4.7" screen iPhone is the smaller version of the iPhone 6 Plus. Identifiable by the model numbers A1549, A1586, and A1589.
4426 Questions View all
replacement battery sits at 1%
Battery replaced, all went well. Got home and went to charge the phone after discharging the new ifixit battery. now it sits at 1% and powers off soon after unoplugging.
did i get a dud battery?
Add a comment
Spread Fixmas Cheer
Get $12 off your purchase of $50 or more with code FIXMAS12
Spread Fixmas Cheer
1 Answer
Chosen Solution
A bad battery is possible. If you could either install a known-good battery or charge yours in another device, then you would know for sure.
However, a lot of iPhones suffer from a defective charge circuit on the logic board. That is the Tristar IC (U2) and the typical symptoms when it fails is no-charge and fake charge. This IC can be damaged by hard falls or using non MFi-Certified chargers. Most of the protection circuitry is in the charging bricks Apple sells. The cheap stuff does not have that circuitry so they can induce voltage spikes that damage your logic board.
Try to resolve if your battery is the problem. If not, you will need to find a qualified repair shop that does micro-soldering repairs.
N.B. If, by chance, your iPhone 6 is still under warranty...go to the Apple store !
Score 1
Add a comment
Add your answer
joe orsini will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 60
