Why does my fuel pump relay wire harness not dispence power
I replaced the fuel pump after having power at the fuel pump fuse replaced it then got no power so I fixed a negative issue had it now I don't my ecm has power but when it gets to the relay wire harmed it don't but I got power from the relay to the oil sensor not to the fuse and only one side has power to the oil it has no ground
Score
0
@jkrumback , Jason help ifixit help you, with more info , what year, make, model, engine size, auto or standard tranny, good battery, turns over good, why did you change pump, any other info. may help. You can add info. in your question or as a comment. Maybe check out this link below.
http://www.fullsizechevy.com/forum/showt...
by L Pfaff
