Repair information and guides for the Apple iPhone 5s that was announced on September 10, 2013. Model: A1533, A1453, A1457, A1528, A1530, A1518
3530 Questions View all
My screen fell out of my phone and the screen cable disconnected.
I had my screen replaced a while ago and the screen has always been loose since then. I dropped my phone and the entire screen disconnected. The cable that connects to the glass screen broke off. I've been trying to figure out which one it is but no luck. Anyone know???
I haven't found anyone with this problem
Update (11/25/2016)
I only have one cable that was connected to the screen...
Score 3
1 Comment
The same thing happened to me but only the top part is loose and it won’t go in how do I fix
by
Add a comment
Chosen Solution
That is the flex for the digitizer that is bonded to the LCD. Replacing your screen is the easiest fix. Attaching that flex requires a very expensive machine that even I can't justify buying.
Score 3
3 Comments:
And your backlight is in pieces. For sure time for a new screen!
by
Thank you!!!
by
And the frame came off!
I am genuinely impressed with the amount of carnage.
by
Add a comment
This is not good. I fear that the flex cables connecting your screen may have torn, partially or completely. There are actually 3 cables connecting the screen (LCD / Digitizer / Camera). There is also a flex cable at the bottom of the screen for the Home button.
Check out this guide to see what is what.
iPhone 5s Screen Replacement
Visually inspect the flex cables and the connectors themselves. If the metal plate was there (assuming a proper repair), it sounds like they are probably torn. If the metal plate was not there, that is a bad repair but it may have saved your flexes.
Can you post a picture?
Score 2
4 Comments:
I only have one cable connected to the screen
I just updated my post
by
The glass separated from the frame...that screen is done. That is symptomatic of a low quality (i.e. cheap) screen. Instead of being glued to the frame, they are held with cheap strip adhesive, which we can see in the picture. Sometimes, as consumers, we want the lowest cost repair but trust me, people who lowball repair prices are just cutting on the quality of the parts, not their profits.
by
I am suffering from the same problem. If I replace the screen, will my phone data( i:e games, screenshots and google searches) still remain? If possible, please respond asap
by
No maybe I’m not sure I’m having the same issue
by
Add a comment
Add your answer
Cam will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 40
Past 30 Days: 200
All Time: 19,256
