Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2397 Questions View all
Microfone problems when call someone
Hi Guys. Since 2 days ago a got a problem with my iphone 4, when i call someone somethings nobody dosent heard me. somethings works and somethings dosent work. nobody heard me but i can heard all. let me know what i need to do, i want to repair my iphone 4
Thanks
Luis
Score -1
Add a comment
Chosen Solution
this phone should still be under warranty. i'd take it back to the shop and let them sort it out
Score 2
Add a comment
Hi to all,
the solutions for this mic problem is to replaced or resolder the BGA ic on the logic board on the part of the upper CPU ic. just try it too carefully.
Br,
Rock
Add a comment
I have 3 solutions
this works on Iphone 4
i have tested all 3 of them, and have had success with all 3 solutions..
The Problem:
Iphone 4 lower microphone stops working.
recording video and memos works fine, but people cant hear me during calls.
just to clear things up for everyone...
when using video recording, memos or anthing else that can record your voice, the iphone is using the TOP MICROPHONE.
when calling/getting calls the iphone will be using the LOWER MICROPHONE.
When you put it on "Speaker" then the phone will use both.
Solution 1:
Change the Dock Connector
if that wont work... then....
Solution 2:
Click on this link, and follow the instructions, on how to fix the Compiler Chip.
iPhone audio problem: fixing an audio compiler chip fault
sounds and looks wierd...., but yes it works....
done it with multiple phones so far...
if solution 1 does not fix the problem, then solution 2 should help allot.....
should the problem still persist, then you might have a problem with your Home button.
See Solution 3 for more info
Solution 3:
Change the Home button.
this last solution was the problem solver for me... i had 7 dock connecters, new and from other broken phones i tested with.
in the end, the home button just gave up when i was swapping around, then i just replaced it, and Voila.... my microphone was working again, and my home button was working too :D
i cant really explain what really happend, but its my 4th iphone i have had these problems with, and all has been repaired with these 3 simple solutions...
i really hope it can help alot of people in here, with issues with iphone 4 microphones not working
Add a comment
Add your answer
Luis will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 7
All Time: 1,789
