Windows wont go up or down
My 2005 Chevy Uplander Windows want go up or down
Hi,
Check to see if the circuit breaker #32 has operated. It is located in the instrument panel fuse block, located under the instrument panel on the passenger side of the vehicle, (see image for circuit breaker location in the fuse block - click on image to enlarge for better viewing)
It it has operated, reset it and then see if it either operates again immediately or if it only operates when you activate a switch to open or close a window.
If it operates immediately upon resetting there is a fault in either the main feed to all the windows' motor drive circuits or in one individual window's motor drive circuit.
If it operates when activating only one window then the fault is in that window's motor drive circuit
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 116
