Can I change bulb in display panel?
Countdown display on front right side. Kenmore elite microwave model #89999 is very dim, can I change bulb?
@kenmoreelite Going by the number you identified your device by it sounds like a Kenmore 295.89999. If the display isn’t working at all, either the main control board or the display board could be at fault. As L Pfaff already pointed out, there are no bulbs on the display.
@kenmoreelite , Pat, Kenmore elite microwave model #89999 could not find any info, for this mdl.#.
The microwave oven is one of the most dangerous appliances to repair, you should have a qualified Tech. look at it. I believe it probably has a digital display and there will be no bulb to change. Links below have more info. for you to check out. Good luck.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 5
All Time: 1,067
