The second generation of the iPad with Wi-Fi, GSM and CDMA models. Some models were refreshed before the iPad 3. Repair is difficult and requires heat and prying. Released on March 11th, 2011. Model numbers: A1395, A1396, and A1397.
730 Questions View all
Black screen post boot, but display functions properly while charging
Hello,
iPad with cracked screen was functioning normally before repair. After replacing screen/digitizer the LCD was unresponsive, but chimes indicated the OS was functioning normally. Oddly the LCD lights up the charging screen as expected when battery is allowed to die. Not a backlight issue as far as I can tell.
Add a comment
1 Answer
Hi Byrd
I hope you didn't glued your new digitizer before testing. Otherwhise I'm afraid that you will have to re-hot it to remove it.
Once the digitizer is removed, check if you positionned correctly the LCD cable to the LCD. (also check the connection of this cable to the mainboard)
It could also be the LCD cable itself.
Add a comment
Add your answer
Byrd will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 5
All Time: 41
