Model A1312 / Mid 2011 / 2.7 & 3.1 GHz Core i5 or 3.4 GHz Core i7 Processor, ID iMac12,2
708 Questions View all
Hard Drive replacement with 2 SSD's in original hard drive bay?
I have a mid 2011 iMac 27inch i7 3.4 . I am wondering if anyone has considered fitting dual SSD hardrives in the existing hard drive bay?
Without doing the teardown and then seeing if it fits, I would like to find out first.
Could there be a build up of heat in this area?
Can anyone see any other problems?
Score 2
1 Comment
While you can have a dual drive configuration, you really can't use the 3.5" bay to house both drives. The height of the two 2.5" drives would be pushing things for the space.
Follow Mayer's link below.
by
Add a comment
1 Answer
Chosen Solution
Here's the Dual hard drive kit:
Installing iMac Intel 27" EMC 2429 Dual Drive Kit (HDD or SSD)
It also has an SD card slot. You can get a TARDISK A13A that will fuse:
https://www.tardisk.com
Score 3
Add a comment
Add your answer
Graham Ladewig will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 444
