Water Damge turned off
My sony xperia z3 compact fell into the water immediately after it is turned off.
What can I do?
What can I do?
Do not under any circumstance is put your phone in a bag of rice! I'd advise you to do is to remove any Sim tray's and most importantly remove the battery from your phone. Then take a blow dryer or hairdryer and heat up the phone.
If possible use an ultrasonic cleaner while also having the battery still out of the phone and 90% or above rubbing alcohol In the ultrasonic clear as the solution.
So i must clean the battery and the phone with alcohol in the ultrasonic cleaner?
The phone is of my brother, He wiped the phone with a paper towel, but did not want to disassemble the phone to remove the battery.
I must clean the motherboard of the Sony with isopropyl alcohol?
Remove the screen and take out the battery whilst having the screen off take the phone and put it in with isopropyl alcohol
So i must remove screen and battery, the rest of the phone it will clean with isopropyl alcohol?
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 132
