Model A1419 / Late 2013 / 3.2 & 3.4 GHz Core i5 or 3.5 GHz Core i7 Processor, ID iMac14,2
340 Questions View all
Is a thermal sensor needed when replacing HDD with SSD?
Hello,
I have found similar questions to mine, most offering to make a fusion drive by adding an SSD blade. This is not a good option for me.
My internal HDD is failing in my iMac 27" (late 2013) and I am using an external Samsung 850 EVO 1TB SSD currently. I would like to remove the HDD and put the SSD inside.
I plan to buy the kit for replacement and a 2.5" to 3.5" tray for the SSD: https://eshop.macsales.com/item/OWC/SSD2...
*My question is however the case of the thermal sensor,* do I need the thermal sensor as seen on the OWC website here? https://eshop.macsales.com/item/OWC/DIDI...
If so, where would I stick the sensor on the SSD?
Many thanks for answering.
2 Comments
Hello,
If you decide to buy the thermal sensor from OWC you will need to plug the cables and stick the thermal sensor on any part of the SSD. If you dont buy the thermal sensor a bypass that work most of the time is HDD fan control app that you will need to install after the SSD installation is complete and if the fans are raving.
by
Hi Alex,
Thank you for answering. As I have read some comments saying the fan control app may not be the best option as some damage was still made after prolonged use I will be buying the thermal sensor as it seems to be a safer option.
Thanks,
Daniel
by
Add a comment
1 Answer
Chosen Solution
Daniel - I strongly recommend you stick with the hardware solution. Overtime we have learned the software direction is not healthy to be dependent on. It tends to lag which can fatigue your logic board and it can over rev the fan causing it to fail prematurely. Both could cost you either a burnt logic board and/or fan unit.
It you care about your investment you'll need to add in the inline thermal sensor from OWC.
I do recommend you install a good thermal sensor & fan app like this one: TG Pro for less than $20 US its worth it to see whats happening and I do use the turbo function when I'm playing a heavy graphics game to keep the system running cooler when it's the most stressed.
Score 3
2 Comments:
Hi Dan,
Thanks for the in-depth answer. I will take a look at the app you recommend once I will make the replacement. As you mention heavy graphics games - do you also run windows on your mac for some games? If so, do you use any windows app for this aswell?
Thanks,
Daniel
by
If you are using BootCamp to run Windows you don't need a Windows version of the App.
by
Add a comment
Add your answer
Danniel will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 7
All Time: 6,442
