Released on September 19, 2014, this 4.7" screen iPhone is the smaller version of the iPhone 6 Plus.
3629 Questions View all
Logic Board connection stripped, what to do?
While trying to fix an antenna issue, a screw felt loose on the wifi antenna cover. When I took it off, the screw and the little copper ring that connected the antenna cover to the antenna on the logic board broke right out in a perfect little circle. I don't have the part and now my phone has terrible reception. What do I do?
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
Without seeing a picture, it's hard to say if it is fixable or not. The "standoff" allows the ground to connect from the antenna cover to the logic board. When it's not there, you don't have that continuity and that is likely causing your reception problems.
Unless you have the tools or experience, I would recommend that you find a qualified repair shop that does micro-soldering repairs. You can also do an out-of-warranty replacement with Apple but be sure to back up your data first.
Score 1
Add a comment
Add your answer
Tinu Thomas will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 39
