The HP Compaq 2510p has a part number GM651AW and was released June 2007. It features an Intel Core 2 Duo ULV processor and 12.1 inch display.
4 Questions View all
My laptop won't power on.
I press my power button, and my computer wont turn on. There's no lights when the battery is plugged in either. Does anyone know whats wrong?
Score 3
1 Comment
Student question
by
Add a comment
Chosen Solution
You can try doing a static discharge . Remove the battery and unplug the laptop so there is no power to it at all . Then hold the power button down for 60 seconds this drains any residual power from the memory and allows a clean boot. Then reconnect the battery and power and boot the computer normally. If this gives no Joy test your power adapter to see if there is an issue there .If the adapters not providing power it wont charge the battery Hope this helps
Score 4
Add a comment
Your battery may be defective. However try removing the battery for 60 seconds and see if the problem persists.
Add a comment
Add your answer
Dan Champagne will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 6
All Time: 2,379
