Repair guides and disassembly information for laptops manufactured by ASUS.
2520 Questions View all
Correcting upside down display
My cat somehow changed my display upside down while I was sleeping. This has happened before, and I was able to adjust it back by Ctrl+Alt+Up Arrow, however; this is working this time. Keyboard is not locked. Any suggestions?
Add a comment
Chosen Solution
Hi,
Right click on the desktop background, click on Graphics Options, then Rotation, then Rotate to Normal.
If you have Intel Graphics installed , right click on the desktop, click on Graphics Properties. Select Advanced Mode click OK. Look for the Rotation settings, on the right side down near the bottom, select Rotate to Normal.
Score 1
1 Comment:
Appreciate the help!
by
Add a comment
@tore37 you did not tell us what OS you are using. Right click on your screen click on screen resolution. See what it says for orientation. It may be at something like landscape flipped etc. Sometimes reinstalling the driver for your video and then retrying the Ctrl+Alt+Up keys may work again.
1 Comment:
Thank you so much for your quick response! Will try when I get home from work ;)
by
Add a comment
Add your answer
Julie McNeill will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 13
Past 30 Days: 75
All Time: 6,313
