The Mac Pro First Generation is an Intel Xeon-based workstation computer manufactured by Apple Inc. The first generation model includes the machines from 2006 through 2008.
Heat Sinks are stuck to the Processor
I've removed the hex nuts from both heat sinks on my Mac Pro 2,1 - I was intending to upgrade the two processors – The Heat Sinks are absolutely stuck as if they are epoxied to the Processor by the thermal paste. No movement what-so-ever, almost as if there is another screw or clip holding them in place. Is there a way to loosen this area with Thermal Material Remover?
Add a comment
1 Answer
Chosen Solution
I would give an ultrasonic cleaner a try with a solvent that can remove (soften) the thermal paste. You should try a twisting motion vs splitting the parts apart.
Just be careful on what you use! As you don't want the fumes to ignite from a spark!
Score 2
Add a comment
Add your answer
Stephen Esser will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 228
