The G3 Controller is gamestop's version of a gamecube controller, equipped with A, X, Y, Z, B, Turbo Button, joystick, C-stick, left and right triggers, and a directional pad.
5 Questions View all
Why is my controller moving the character when I am not
My controller causes my character to move when I do not move the control stick. Is it dirty or is it just a bad signal?
Score 2
1 Comment
Turns out there was an error when the console recognized the controller so I just unplugged it and re-connected it to the console.
by
Add a comment
Most Helpful Answer
Often times, disconnecting the controller and blowing into the connection port on both the controller and console can fix this problem.
Score 1
Add a comment
Add a comment
It may be dirty or your joystick may be misaligned. I recommend you check out our joystick replacement guide, and use the steps to clean out the area and then reattach your joystick. If the problem still persists it may be a problem with your motherboard.
Add a comment
Add your answer
Andrew Gonsalves will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 6
All Time: 356
