Repair information and support for speakers designed to be used with a personal computer.
55 Questions View all
How can I repair genius satelite 2.1 SW - S2.1 900 ...
Hello the problem with how can i repair genius satelite 2.1 SW - S2.1 900 is in the din connector 9 pin, the cable broke and I do not know in which order the cables I have bought a replacement plug to weld it but I do not know Color order anyone can help me? Attached image of system 2.1 and connector
The colors of the cables are
Red
green
yellow
blue
White
black
orange
Brown
And a ground wire that in the metal part of the connector
http://www.geniusnet.com/Genius/wSite/pu...
https://ae01.alicdn.com/kf/HTB1_yWwKXXXX...
https://sc02.alicdn.com/kf/HTB1akQYIFXXX...
3 Comments
Hello
I only got loose dres and a new Conector, but I can not continue without colors for the PINs connection. Maybe someone has the connection scheme with the colors?
po.mi@gmx.at
by
I have the same problem
Have you been able to solve it?
by
I have no time in the moment, but if you disassemble it, you can find the connections logical. There are the wires to 2 boxes and 2 controllers. I'll do it later. Then I write it down.
by
Add a comment
Chosen Solution
Hi,
If the old DIN plug end has even a couple of inches of cable still attached to it, strip the sheath of the cable up to the DIN plug so as to expose the wires. Then using a DMM (Digital Multimeter - Ohmmeter function These are available at hardware stores for about $10), strip about a 1/2" of the insulation off each wire, one at a time and try to locate it by connecting one end of the Ohmmeter to the exposed wire and then searching for which DIN connector pin it is attached to by touching each pin in turn in the DIN connector until the Ohmmeter registers a reading.
Make a drawing of the DIN connector, numbering the pins so that you can write down the colour of the wire next to the pin number (and its location) in the plug.
Do this for each wire until you have identified them all.
Be careful when you touch the DIN pin with the Ohmmeter test probe as you do not wish to 'bridge' the probe between two pins.
Use this image as a guide to numbering your plug. There are a few different numbering schemes, for you it is not important as long as you reconnect the wire back onto the same pin location that you identified when using the Ohmmeter Click on the image to enlarge it for better viewing.
Score 1
1 Comment:
1 Yellow R in
2 Black Gound
3 Blue L in
4 NC
5 Orange R Volume
6 White R Spekaer
7 Green +12V
8 Brown L Volume
9 Red Bass Volume
10 Shading, Ground
1 day of work to fix it ....
by
Add a comment
Most Helpful Answer
1 Yellow R in
2 Black Gound
3 Blue L in
4 NC
5 Orange R Volume
6 White R Spekaer
7 Green +12V
8 Brown L Volume
9 Red Bass Volume
10 Shading, Ground
Score 2
1 Comment:
thank you very much good man. God bless you.
by
Add a comment
Add your answer
GUITARPLAYER RANDALL will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 11
All Time: 1,084
