Sound problem with one speaker
The sound from the left hand speaker is much weaker than from the right. What can I do?
Add a comment
1 Answer
Chosen Solution
Hi,
Try swapping the connections between the left and right speakers so now the left speaker is actually fed from the right speaker output of your amplifier and the right speaker is fed from the left speaker output of your amplifier to see if the problem is with the speaker or your amplifier.
Do not move your speakers when you do this or if you have to mark them so you know which one was the original left speaker and the original right speaker
The problem should now be in the right speaker if the amplifier is faulty and still be in the left speaker if the speaker is faulty
If the problem is with the amplifier what is the make and model of the amplifier?
If the problem is with the speaker you may have to open the speaker box to gain access to the pcb board to see if there is a problem there etc.
Score 3
Add a comment
Add your answer
John Morrill will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 3
All Time: 119
