Dock connector works just when heated
Hi! I've got the common problem with the dock connector of my ipad: no volume control, mute speakers; it shows only "Apple TV" and "Dock connector" on the airplay available devices. it "believes" that's connected to a docker connector.
The only way to make it work is blowing some hot air with an hair dryer, but after 5 minutes the volume control disappears again.
Have I to replace the dock flat cable or can I try something different?
well i have 3 ipads and i think 1 is the same you have but the headphone plug is when you use a heaphone the airplay is sound and video so sound is from there and my sisters ipad volume control got sticky and dident work so its just pull the volume and it shuld be put it back abd it works again
by old foxy
and the cable is made of hair thin cables that break easy bellive me i have lost 5 chargers i think but now i foundout my female side on the ipad is wiggle up down that makes it hard to get power bit it can show it gets =_= i took some salive on the charge cable and plug it in it worked for a wile i mean apple have made the cable i have a broken i show you what apple are good for -.-
by old foxy
