Not support setup box
My tv model is. PS-42D4S
This is plasma tv. Its not support setup box or cable tv also...
How to solve this...
Hi,
If your STB or cable box has HDMI output, then you need to have something like the following:
a powered HDMI to Component Video converter to connect between the device and your TV.
http://www.cablechick.com.au/cables/hdmi...
or a HDMI to AVI (Composite video) converter
http://www.ebay.com.au/itm/Simplecom-CM4...
Search online in your location for suppliers.
Hi,
Thank you, In my STB box has AVI out. I tried with 3 RCA Cable to TV but the problem is its not connected. its shows NO signals or searching signals. But it will connect some time for 1 or 2 mins then again signal lost....
Hi, Just verifying. You connected your STB to yellow/red/white AVI inputs on TV? Switched the TV to the correct input using the remote control input button?
Have you proved that the STB output is OK selecting menu option in the STB using the STB remote control and getting a stable picture on the TV?
What is the make and model number of your STB?
Hi, I checked all inputs... and the STB working perfectly in other TV also. But
its not working in my TV
Hi Again just checking. You are connecting the STB to the S-Video/AVI connection input on the rear of the TV? I know it is not S-Video, just the AVI Connections next to the S-Video input.
Have you also checked that the input is not actually an output? Apparently on your TV it can be either AVI -IN or AVI - OUT depending on the setting. Here is a link that shows you where it is in your TV.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 130
