Repair information and guides for the iPhone 6S released by Apple on September 25, 2015. Models: A1688, A1633
2692 Questions View all
Speaker, Microphone and Vibrate not working
Hi there,
I have an iPhone 6s 64GB I purchased knowing the speaker and vibrate were not working, so I purchased parts and replaced them, but that has not solved the problem. Additionally I found the microphone wasn't working either.
I was wondering whether the last resort would be to replace the mother/logic board on the device, and if this would make any difference?
Thanks
1 Comment
Clean all connections and check for water damage on the logic board.
by
Add a comment
1 Answer
Most Helpful Answer
you definitely want to check first and foremost if it is water damage, does the charging port work? I would certainly find out and see if it is corroded or does it still look wet. It very well could be the logic board
Score 2
1 Comment:
Look for corrosion on the board, and take some isopropyl 90%+ alcohol and lightly brush the affected areas. Isopropyl helps evaporate corrosion on logic boards.
by
Add a comment
Add your answer
Zac Webb will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 343
