Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Questions View all
Overheating? wont make calls all-touch stops.
I had a customer bring in an iPhone 6 that gets very hot. I am wondering if its a lost cause, it turns on and stays on gets very hot the digitizer stops working, it wont make phone calls. its connected to wifi says service is there. i Tried a new battery and screen and the same thing still happens. i have checked their settings and nothing is set to stop calls. if anyone has any experience with this particular issue i would LOVE to know how you fixed it, or if its not fixable at all. THANK YOU
Add a comment
Most Helpful Answer
Almost certainly board level damage. Usually due to water damage but it could have been due to a drop. Since multiple systems are not working, I'd lean towards water damage.
Score 1
Add a comment
overheating is probaly down to a damaged or loose ic
1 Comment:
I went ahead and did a system restore and update, has cooled down since then, keeping an eye on it. will keep the ic chip in mind i know how those can be quite the problem
by
Add a comment
Add your answer
Veronica Royal will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 115
