Repair guides and disassembly information for PC laptops of all shapes, sizes, and colors.
18921 Questions View all
Laptop freezes after few minutes of starting up.
I have an HCL laptop which on startup freezes completely. Following is what happens:
  1. The start button is pressed and the laptop switches on...
  2. The laptop surpasses the BIOS screen...
  3. The laptop is dualboot b/w Ubuntu and Windows, I can choose either...
  4. It will work for 10 mins maximum and freeze (screen freezes, nothing else works)...
Need help...
2 Comments
Hi,
Has the CPU or chipset been overheated in the past?
If you have 2 sticks of RAM try either Memtest 86 to test them or remove 1 stick at at time and see if it occurs.
by
hello , try removing some start up program using task manager and check to see if it a hardware problem . for any other software issue follow the post http://fixingblog.com/top-10-tricks-quic... . see if any of that solves the issue .
by
Add a comment
1 Answer
Chosen Solution
Have you tried to overclock it because that can cause the hardware to freeze if not then have you installed anything recently if so boot in safe mode and remove it and see if that works
Score 3
4 Comments:
Thanks, Sean. I'll try doing that but overclocking might not be the reason because I refreshed both the OSs and both have nothing on them except their native apps with the freezing recurring. Thanks anyway.
by
@ifixyou - Thank you, that was the correct solution! :)
by
If you never overclocked it and have not installed apps recently then the bios may be bad and needs to repair/replaced with an update or firmware flash
by
My laptop freezes after 3 minutes and also if i open some apps or folders. But my cursor i.e the arrow can move . How can i fix this?
by
Add a comment
Add your answer
Whatever will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 5
All Time: 5,466
