Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
1158 Questions View all
White apple logo for about 10 secs then dims and never boots
Hi, I've done my reading and am stuck. My iPhone had a broken volume switch and broken home button. I sucessfully replaced both. I should have left it alone. The problem came about because when I replaced the home button my LCD had some visible dirt that bothered me. At this point my phone was fully functional. I simply took it apart to clean the LCD and glass. When I put it back together it quit working. I must have taken it apart 10 times by now and checked everything. I even replaced the battery and got the same results. This is what happens: If you press the power and it's not plugged into ac power nothing happens. If it's plugged in then the apple logo appears for about 10 secs and then thr screen dims and you can see the apple logo faintly and that's it. Connected to the pc nothing happens. I hope someone has some help with this. It's been a long week without a phone. TIA
Score -1
1 Comment
*Update* I just took the mainboard and put it in a different case and got the same results. So I'm concluding it's a mainboard issue. Is there anyway to fix this? Thanks
by
Add a comment
1 Answer
Chosen Solution
I've had a problem similar to this. Only part I could find damaged was small component in top left corner of motherboard near connector 5. Phone had been dropped- damage was to volume controls. I am not that knowledgeable to identify the part maybe someone else is....
You could try removing metal cover to motherboard and inspecting for damage in that area..
Score 2
Add a comment
Add your answer
Steve will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 1,212
