ouvrir la porte arriere
ouvrie la porte de la malle
quelqu'un a-t-il le manuel en français
google Translation
Ouvrie the door of the trunk
someone he has the manual in French
google Translation
@herve13 , Try the center console tailgate unlock window button first and child lock out switch off if equipped. Window and tailgate will not work if rear wiper is not in the proper resting place on rear hatch, if not sitting in proper position in off (on its perch)position, turn on rear wiper and cycle it. Check and test all rear window fuses,relays, "power window relay" this part is behind the plastic panel in the back on the drivers side. Two bolts hold it in, simply buy a new one if found to be faulty. Very good links below to help explain how you test and diagnose rear window/hatch problems in your 4 runner. Check the attached links,instruction and guides, Good luck.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 10
All Time: 168
