Why I have lines on display
Why Iphone 5c has floating lines all across display, the rest is working fine
Turn the phone off, disconnect the battery and disconnect the lcd and digitizer cables. Reconnect the lcd and digitizer cables firmly, then the battery and turn it back on. If the problem is still there, it's probably a faulty lcd. I have fixed hundreds of iPhone 5c's and run into this issue every now and then.
Thanks Brian, Thanks James, it worked.
Luckily, I do not need new lcd. After reconnecting cables all back to normal
You're welcome. Im glad that worked for you.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 63
1 Comment
Anything happened that may contribute to that issue prior to it happening?
by Ben
