The second generation of the Recreational Active Vehicle with 4-Wheel Drive, commonly known as the RAV4.
7 Questions View all
Why don't my daytime running lights work
My daytime running lights on my 2003 Toyota rav4 stopped working my headlights only work when I put them on high beem.
Comments:
i would check your fuses, and then if all fuses are good try a new bulb.
by
Add a comment
1 Answer
Chosen Solution
Jose,
First thing. Daytime runners are to be on when the headlights are off. Now the RAV 4 may possibly be setup to "add" them with the high beams, which may be why your seeing them.
Like the first answer said. Check the fuses, inside car and under the hood. They run through the head light switch, which could be problem.
I'll look into it and see if there is anything to be found.
Score 1
Add a comment
Add your answer
Jose valles will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 18
All Time: 520
