Repair information and guides for the Apple iPhone 5c that was announced on September 10, 2013. Model: A1532, A1456
1233 Questions View all
"No sim" Stuck on activation screen
I bought 2 sim cards and put them in the slot (I cleaned them both) after i run through my language and country it asks for a wifi or itunes I have selected both before same error message after I click next when i select wifi it says " "sim required" "please insert a sim card"
BUT after i slide to unlock it says "no sim card installed" "insert a valid sim with no pin lock to activate this iphone"
PLEASE HELP
Score 1
1 Comment:
Check the sim reader for any broken pins and the board for any signs of corrosion failing this it will most likely need to be sent to a micro solderer for repair. good luck.
by
Add a comment
1 Answer
Did U try the sim cards on another phone ? if they worked U need to check the sim reader or the part that will use ur sim card maybe it has a problem
Add a comment
Add your answer
Gamers Place will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 2
All Time: 355
